Product Compliance _ Vigilohm and Variable Speed Drives
Metering & Power Quality
Send InviteCancel
2015-10-0506:05 AM
The " Product Compliance _Vigilohm +Variable Speed Drives" kit shows the full compatibility between Vigilohm Insulation Monitors and Variable Speed Drives.
Key Points:
- Schneider "All in One": Vigilohm + Altivar
- Solution which was tested and validated
- Available for all application fields and segments using IT earthing system
This kit contains the following documents:
- A 2-page flyer with key messages on the compatibility between Vigilohm and Altivar - To be shared with sales and customers
- A 25-page Application Note with examples of applications of Vigilohm+VSD, recommended settings, details on the tests -Beneficial for internal teams
- A 30-slide presentation to be used if you wish to present key messages on Vigilohm+VSD
