Share Your Feedback – Help Us Improve Search on Community! Please take a few minutes to participate in our Search Feedback Survey. Your insights will help us deliver the results you need faster and more accurately. Click here to take the survey
Hi Guys,
I can't find information about the measurement capabilities of the N-Terminal of PowerTag A9MEM1521/22, are the same as the phase-Terminal?. We're planning to use these PowerTag references for a 2-phase system, any other ideas? is better to use 2 A9MEM1520 instead?
Thanks!!! 🙂
Hello @sesa453448_brid ,
Can you precise your architecture ?
N Terminal for any PowerTag Sensor has no CT. It is only used as a Voltage Reference so you cannot monitor any current on the Neutral.
If I understand your system will be : N, L1, L2 (No L3 ?). If you plan to use A9MEM1521/22 => it means that you have Acti 9 MCB. Can you give me the commercial ref of the breakers ?
Depending on your answer I may suggest you some configuration.
Hello Romain
I want to conect A9MEM1570 in L1-L2-L3 system (No N). Will be any problem if i no conect the N terminal of powertag?
Hello @marco_arias_ssm ,
If you have a 3ph system without Neutral : it is more recommended to connect a A9MEM1573.
If you use the A9MEM1570 and if your system is balanced : your measurement precision will not be affected. But.... what are you going to do with the N pin of the PowerTag 1570 ?
Keep in mind that 1570 is dedicated for 3P+N unbalanced system. Neutral will improve the precision of the Power measurement.
Regards.
Thanks Romain
I ask about the A9MEM1575 reference. I only see the A9MEM1570 in stock.
A9MEM1575 does not exists. I mentioned A9MEM1573 in my previous comment.
Please refer to the selection guilde.
Regards.
