Continue
  • My Subscriptions
  • Events
PowerLogicTM VL series- Modbus Setup
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PowerLogicTM VL series- Modbus Setup
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Arunprasad
Arunprasad Mentor
Mentor
Posted: ‎2023-03-12 09:53 PM
Hello All,
We have done a small modification to the Modbus parameter setting. Modbus parameters must be configured through the expert setup menu in section 700 (see PowerLogic™ User manual paragraph 5).
• BAUD RATE (701): the valid range is 1200 - 115200 baud.
Default value = 19200.
• PARITY (702): parity to be None, Even or Odd.
Default value = Even.
Note: For PARITY = None, use 2 bits stop. For PARITY = Even or Odd, use only 1 bit stop.
In general if Parity was set as Even or Odd then set as ----> 1- bit stop
But if the Parity was set as Noe then set as----> 2 bit stop
• SLAVE ADDRESS (703): the valid range is 1 - 247.
Default value = 1.
The settings for baud rate and parity must be the same for all bus devices, the address must be unique for each device.
Modbus set-up VPLModbus set-up VPL
Arunprasad
  • Power Quality
Replies 0
