I have a PM8000 which is alerting me to a firmware downgrade and I am not sure if it is true.
The Firmware I am trying to push is 001.003.001 and the current device firmware is 001.002.014 which to me looks like a older firmware.
I thought V1.3.1 was the latest PM8000 Firmware, no?
This is likely an ION Setup issue as moving from the old firmware versioning system (ex. V407) to a 3 part one (A.B.C) as I've had to try and equate them in some fashion (and never mind trying to figure out how to reference them in files).
What build of ION Setup are you using?
Thanks. I am using ION Setup 3.0. Is there a newer version?
It's been 3.0 for a very long time but look at the Help -> About to see a particular build number (presently the latest version is 3.0.17307.1).
If you have a recent enough build #, simply select under the Help Menu => Check for Update if your PC has internet access and Box is not blocked by your IT department.
