PCS plus with issue: Control Board Initialization Progress
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • PCS plus with issue: Control Board Initialization Progress
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
194
Ramasamy_N
Ramasamy_N Champion
115
PowerLogic
AccuSine PCS+
tien_dat
tien_dat Explorer
Explorer
Posted: ‎2023-05-08 09:13 AM
3771
Hello Communities,
I met the issue with PCS Plus during commissioning as below "Control Board Initialization Progress…” Could you help me with this case?
Thank you
  • Thumbnail of AccuSine PCS+
    PowerLogic
    AccuSine PCS+
View products (1)
  • Power Quality
Arunprasad
Arunprasad Mentor
Mentor
Posted: ‎2023-05-09 11:36 AM
2
3736
Hello Tien Dat
"Control Board Initialization Progress…” means, it is try to reboot by itself , this kind of symptoms are observed when the unit in Turned on with the input supply, but important thing is it get disappears after sometime, so what i want to understand is, did this symptom was continuously displaying on the screen.
If the answer is Yes, then it is due to some event happened in the unit.
From the image shared, i could see Red Flag was pop-up in the HMI, it clearly determines that there could be some event in the unit.
Can you capture the fault event by pressing the Red flag,  i mean when you press the Red flag, it will take you to the next screen , where you can see the fault event . Please capture a small video or an similar kind of image and share it with us.
In addition, i recommend to download the Event log file from the HMI .
Event Log screen displays events that occurred.
Touch an event to select it.
Press the magnifying glass icon  to display the details for that event.
You can save the Event Log to a USB storage device.
Once it is connected, press this icon to save the file.
In addition to that, please collect the commercial reference , unit serial number and is the unit is standalone or connected in parallel.
Note: After collecting all the detail, i recommend you to raise a BFO case through your country "CCC" team, Customer Care Center. Here below attached the link in both English and Vietnamese
https://www.se.com/vn/en/work/support/customer-care/contact-schneider-electric.jsp
Vietnamese
https://www.se.com/vn/vi/work/support/customer-care/contact-schneider-electric.jsp
Regards
Arunprasad
Arunprasad
Arunprasad Mentor
Mentor
2
3737
Hello Tien Dat
Vietnamese
Regards
Arunprasad
tien_dat
tien_dat Explorer
Explorer
Posted: ‎2023-05-09 05:09 PM
3732
Thanks, Arunprasad,
I send the nameplate of the product, event log, T&C file as an attached file.
The active harmonic filter appears in this message only with unit status 1/4. After appearing this message, then PCS+ could not permit it to run.
We will send you a video about red flags as you guide later
Notes, the unis operates  in standalone mode
AL230430000000-T&C.txt
AL230508010000-Evenlog.txt
Arunprasad
Arunprasad Mentor
Mentor
Posted: ‎2023-05-10 12:05 AM
Hello Tien ,
As i mentioned above,
Press the Red flag and capture the Event that display in the HMI.
Please raise a BFO Case in CCC, we don't use this forum to discuss  more in detail.
So again i request you to raise a case and add the details to the BFO Case.
Hope you can understand.
Regards
Arunprasad
