MODBUS exeption response from slave device ION9000
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • MODBUS exeption response from slave device ION9000
Charles_Murison
Charles_Murison Champion
570
Mehran_Mehrnia
Mehran_Mehrnia Champion
201
Ramasamy_N
Ramasamy_N Champion
115
huseyinb
huseyinb Mentor
Mentor
Posted: ‎2019-08-09 12:23 AM
4485
When i can write data to register with modscan i get this error,
how can i solved this problem
Charles_Murison
Champion
Posted: ‎2019-08-21 04:19 PM
Hello Hüseyin,
Currently the ION9000 does not support reading data recorder values via modbus. The document has this ranged reserved for possible future use.
Charles
Replies 12
Charles_Murison
Champion
Posted: ‎2019-08-09 09:08 AM
4477
Hello Hüseyin,
Would need to know a lot more information.
What registers are you trying to write to?
What values are you try to write?
Modbus Gateway enabled?
What device ID does the request go to?
Do you know what exception you are getting back?
I assume you are talking to an ION9000 and not a device downstream of it.
huseyinb
huseyinb Mentor
Mentor
Posted: ‎2019-08-19 02:07 AM
4471
Hi Charles,
I tried Data Recorder with 53001 register address,
Charles_Murison
Champion
Posted: ‎2019-08-19 09:34 AM
4468
Most Modbus registers in the ION 9000 are read only. Especially data recorders. what it is that you are trying to do?
huseyinb
huseyinb Mentor
Mentor
Posted: ‎2019-08-19 11:12 PM
4463
i need Data Recorder Module values,
Charles_Murison
Champion
Hello Hüseyin,
Charles
Tom_Stevenson
Tom_Stevenson Champion
Champion
Posted: ‎2019-09-05 09:42 AM
4447
Hi Huseyin
Register 53001 is not in the ION9000 register map.  Where are you seeing this information?  Data Recorders are not available through Modbus protocol.
Tom
Charles_Murison
Champion
Posted: ‎2019-09-05 10:48 AM
Hello Tom,
This is from ION9000_Modbus_Map_002.000.000.xlsx. I have already highlighted this to product owner.
huseyinb
huseyinb Mentor
Mentor
Posted: ‎2019-09-06 01:46 AM
4440
customer need data recorder, they use 3rd party software.
Charles_Murison
Champion
Posted: ‎2019-09-06 02:34 PM
Hello Hüseyin
Data recorder information is only supported with ION protocol, not available with Modbus.
huseyinb
huseyinb Mentor
Mentor
Posted: ‎2019-09-09 06:45 AM
4434
Hi Tom,
I found this register on Register Map,
Yut
Yut
Leader
Posted: ‎2019-10-11 01:13 AM
4418
Old document "Modbus Protocol and Register Map for ION Devices_70022-0124-01" has described how Modbus Data Recorder retrieval  is. See if it is compatible to the ION9000 but I'm sure the 3rd party software will not be able to retrieve them since in standard Modbus there is nothing  descripe  about data recorder  unless you have to develop custom application.
Tom_Stevenson
Champion
Posted: ‎2019-10-11 11:44 AM . Last Modified: ‎2019-10-11 11:45 AM
The data recorder bank of Modbus registers are reserved, but are not implemented on the ION9000 as mentioned above.
BR
Tom
