Is possible to have neutral current harmonics evaluation in ION8650A?
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • Is possible to have neutral current harmonics evaluation in ION8650A?
Charles_Murison
Charles_Murison Champion
570
Mehran_Mehrnia
Mehran_Mehrnia Champion
201
Ramasamy_N
Ramasamy_N Champion
115
Ezequiel-PROLUX
Ezequiel-PROLUX
Contributor
Posted: ‎2019-05-30 12:45 PM
2072
Hi all!
If so, please give me a advice.
Thanks in advance!
Charles_Murison
Champion
Posted: ‎2019-05-31 12:13 PM
Correct, calculation would have to be done for each individual harmonic. The meter already has per phase harmonic informaion, no additional modules required. The harmonic modules get information from modules that get information form modules etc that read signals directly connected to the meter so there is nothing for netural current directly.
Replies 4
Ezequiel-PROLUX
Ezequiel-PROLUX
Contributor
Posted: ‎2019-05-31 04:43 AM . Last Modified: ‎2022-10-19 02:55 AM
I found this topic that helps with calculating the module of neutral current:
https://community.se.com/t5/Power-Metering/True-RMS-current-for-neutral/m-p/23269#M68
But I can't put that calculated value into the FFT module for I4. So I could have the harmonic evaluation from it. The I4 used is always zero and I can't change the input of the FFT.
Charles_Murison
Champion
Posted: ‎2019-05-31 09:50 AM
2066
The process described in the KB is on a per-harmonic basis. There is no I4 input to the meter to feed into FFT.
The ION8650 meter already comes with the modules already in the template.
Ezequiel-PROLUX
Ezequiel-PROLUX
Contributor
Posted: ‎2019-05-31 10:12 AM
2063
Hi Charles!
Thanks for the input.
So that calculation should be done for each individual harmonic, is what you mean?
And about the modules that you said ION8650 already have, you  mean the individual per phase harmonics,  coming from the HME (Harmonics Measurement) ? Because for neutral individual current I didn't find any  module...
Charles_Murison
Champion
