If replaced an ION7650 meter, How to backup and transfer the existing custom VIP and framework to new meter ?
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • If replaced an ION7650 meter, How to backup and transfer the existing custom VIP and framework to new meter ?
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
194
Ramasamy_N
Ramasamy_N Champion
115
sesa126789
sesa126789 Leader
Leader
Posted: ‎2013-11-27 09:21 PM . Last Modified: ‎2020-04-22 01:53 AM
1103
As title, has any body can support the step by step instruction ?
  • ION Setup
  • framework
Robert_Lee
Robert_Lee Champion
Champion
Posted: ‎2013-11-28 09:25 AM
Its been a while since I've used ION Designer to do this but I believe the steps are:
1.  Go to ION Designer and open the existing meter diagram.
2.  Navigate to the top most window where you can access everything and from the Edit menu I believe, do a Select All.  This should switch every object on the diagram to be selected.
3.  From the File menu (or maybe Edit), select Copy or Save to Framework.
4.  Enter a filename to save the template file.
5.  Open the new meter diagram in ION Designer.
6.  Navigate to the top most window and do a Select All.
7.  Select Delete from the Edit menu and confirm the deletion.
8.  Once deleted, go to the Edit and select Paste from Framework.  Select the framework file you saved above.
9.  When the paste dialog appears, highlight everything in the list and click on the icon until all the icons show a little lock symbol (this is a lock paste).
10.  Click on the OK to start the process and then select Send & Save changes I believe to send the changes to the device.
You should check with the PME team if this is the correct procedure as its been a while since I've worked with Designer.
