Continue
  • My Subscriptions
  • Events
ION9000 v3.0.0 modbus comms
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION9000 v3.0.0 modbus comms
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
ShaunTaylor
ShaunTaylor Contributor
Contributor
Posted: ‎2021-10-22 05:07 AM
3435
We are communicating from PME to 5x ION9000 meters over ethernet. On loss of voltage phases, the meters remain powered as they should, and comms to PME keeps working as it should,
These meters are also communicating to SCADA over modbus.
4 of the meters are firmware v2.2.1, and on loss of phase voltage, the modbus comms continues to the SCADA as expected.
However...
1 of the meters is firmware 3.0.0, and on loss of voltage, the modbus comms drops out to the SCADA.
All 5 continue to communicate to PME over ION. All meters remain fully powered up.
My question is whether there has been any cyber enhancements or bugs that may be causing the modbus comms to drop on loss of phase voltage? Anyone experience this? Is there a fix/setting?
We're doing further investigating on site but any suggestions are welcome.
  • ION9000
Charles_Murison
Champion
Posted: ‎2021-11-15 10:59 AM . Last Modified: ‎2022-10-19 01:17 AM
Hello @ShaunTaylor  and @sesa28787_bridg
Please see https://community.se.com/t5/Metering-Power-Quality/New-Firmware-version-3-1-0-for-Advanced-Meters-is... for more information on V3.1.0 release.
Charles
Replies 6
Tom_Stevenson
Tom_Stevenson Champion
Champion
Posted: ‎2021-10-22 08:25 AM . Last Modified: ‎2022-10-19 01:20 AM
5
3429
Hi Shaun - there is a chance that what you are seeing is described in this post.  There is an upcoming firmware release that addresses it in the case that it is, but the post provides a few workarounds to try in the near-term.
https://community.se.com/t5/Metering-Power-Quality/The-Value-of-quot-N-A-quot-register-of-PM8000-fir...
BR
Tom
ShaunTaylor
Contributor
Posted: ‎2021-10-25 12:38 AM
3419
Thanks Tom, it does sound like the issue could be caused by the same issue affecting the PM8000. I assume ION9000 shares the same framework issue.
We'll do some more investigation on site, and keep an eye out for the f/w update.
Regards
Shaun
Tom_Stevenson
Champion
Posted: ‎2021-10-25 08:24 AM
3412
Hi Shaun - it is a firmware issue, but one of the workarounds is in the framework.  Firmware is shared across the ION9000/PM8000/ION7400, so typically when you see a version number 3.0.0 (ie) across these 3 families, you will find behaviour in common.  The same goes for ION frameworks - built and released as a family of them.
Tom
sesa28787_bridg
sesa28787_bridg Explorer
Explorer
Posted: ‎2021-10-27 08:22 AM
3375
When do you expect a new firmware version to be released that addresses this issue?
Tom_Stevenson
Champion
Posted: ‎2021-10-27 08:34 AM
Hi Shaun - I will let @Daniel_Brandao comment on the official timing.
Tom
Charles_Murison
Champion
Charles
