Continue
  • My Subscriptions
  • Events
ION7550RTU Forgotten IP adres
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION7550RTU Forgotten IP adres
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
YvesR
YvesR Explorer
Explorer
Posted: ‎2016-12-15 11:18 PM
1549
On a project with several ION7550RTU the client entered a IP adres but do not know it any more
The ION7550RTU are without a screen.
I tried with wireshark but cannot find the IP adres
Is there a factory (re)setting or other possibility for a IP trace or IP factory?
Thanks in advance
Yves
sesa56314
sesa56314 Leader
Leader
Posted: ‎2016-12-21 10:03 AM
You could use nmap as a tool to scan a range of IP addresses that might be used by the RTU.  nmap will report the MAC address.  An RTU will have a MAC address that starts with 00:60:78.
Depending on the security settings, an RTU might typically have ports 23, 80, 502 and 7700 open.
The nmap command I used is:
nmap -p 23,80,502,7700 10.168.69.100-150
and it returns, among others,
Nmap scan report for 10.168.69.133
Host is up (0.00098s latency).
PORT     STATE SERVICE
23/tcp   open  telnet
80/tcp   open  http
502/tcp  open  mbap
7700/tcp open  unknown
MAC Address: 00:60:78:04:56:41 (Power Measurement)
From there you can log into the web page and verify the serial number or owner/tag information.
Hope this helps.
Art
patrickw
patrickw Contributor
Contributor
Posted: ‎2017-01-03 11:53 AM
The RTU should send out a gratuitous ARP packet on powerup as well, which wireshark will capture.  Filter on ARP and it should show up around 10-15 seconds after power is applied.
Yut
Yut
Leader
Posted: ‎2017-01-04 08:08 PM
Have you try using ION Setup via serial port ?
