Continue
  • My Subscriptions
  • Events
ION Setup - Report from ION 7400 (Synchronization vía IRIG-B)
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION Setup - Report from ION 7400 (Synchronization vía IRIG-B)
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2019-03-19 04:22 PM . Last Modified: ‎2020-04-22 01:05 AM
1701
Hello Everyone
How are you?
I have a problem when I generate a report by ION Setup, let me tell you.
First, I have an ION7400 meter synchronized by IRIG-B. The strange thing is this meter take the Universal hour like Local hour.
Peru Local hour = GMT -05:00
Figure above you can see the Local hour = Universal hour.
If I don’t configure the timezone in ION7400 the hour is right in frontal display.
But it doesn’t work when I generate a report by ION setup, it shows the local hour -05:00 h per data.
So what could I do to fix this problem with report?
And, I don’t see if this affect in PME reporter when the data is stored in database.
Please help me with this issue.
Best regards
Farid Yauri
  • ION Setup
Robert_Lee
Robert_Lee Champion
Champion
Posted: ‎2019-03-26 09:07 AM
1
1693
Your issue is that you need to configure the Clock Settings to properly use IRIG-B as the Time Sync Source and possibly set the Time Sync Type to match whatever the IRIG-B is sending out (might be LOCALTIME and not UTC).
Robert_Lee
Robert_Lee Champion
Champion
1
1693
Posted: ‎2019-04-30 08:29 AM
Hello Robert,
Yes, that was the solution, the source (GPS) is sending sync in LOCALTIME, I changedTime Sync Type to this option and now the meter have the correct time.
Thank you very much.
