Posted: 2015-11-18 04:04 AM
Posted: 2015-11-25 10:53 AM
Hi Dadi,
I will admit I am not familiar with the terminology "Voltage Cut Duration", would you be able to rephrase your question or give an example of what it is you are trying to accomplish and the gap you are currently facing.
I can tell you that the meter is capable of measuring the the duration of dips, interruptions and outages. Which can then be fed using custom frameworks to be used in calculations.
Brian
Posted: 2015-11-18 06:07 AM
Hi Dadi, I am just moving this question to the right forum. I got stuck in an intermediate location and will move you to the correct one as soon as possible. Thanks for your patience!
Matthew Curry, please move this to Power Metering. I don't have privileges to move a post below Monitoring Hardware.
Hi Dadi,
Brian
If you mean sag or dip when the meter is set properly with nominal voltage level and sag/swell limit the interruption can be analyzed from the waveform recorder it record when the sag/dip occurred and when the voltage is back to normal with timestamp.
Posted: 2015-11-26 11:59 AM
I believe the sag swell module has outputs that give the disturbance duration in seconds.
Yes, there is the table contains magnitude and duration.
