I need to know if there is a way to download the trending and forecasting data from the webpage of an ION PM8244 meter to a .CSV file in order to view them in Excel ?
Metering & Power Quality
Send InviteCancel
2017-03-1907:32 AM
I can see the small graph on the meter’s webpage, but I need to have the actual data (1 week’s worth at a time) downloaded into either a .CSV or .XLS file.
Is there a way to do that simply by using the Meter webpage ?
If not, can it be done using ION Setup to export data from that meter to a .CSV file ?
If not, last choice….if we use the web page of a Comx510, can it export data to a .csv file
2017-03-2201:28 AM
Hi Yves,
I had a chance to look at this and while you are unable to export the information directly from the devices webpage, you can get historical data through ION Setup in a .csv format.
Using ION Setup > Setup Assistant > Reports I could extract 7 days of data from the EnergyDemand Log. In the data set is kW sd del-rec, recorded in 15 minute formats. You should then be able to plot that data into a graph to show your trend, but additional formula work would be need to generate forecasting data.
My Com'X 510 is currently off-line so I was unable to explore that option.
2017-03-2201:28 AM
Hi Yves,
