Continue
  • My Subscriptions
  • Events
I’m looking to create a tag through a Modbus list through a Schneider 5110 device. Its showing that the data type is “4Q FP PF” which were not too sure how to set up. The images below show the registers and the data types.
Metering & Power Quality
  • EcoStruxure Power & Grid
  • I’m looking to create a tag through a Modbus list through a Schneider 5110 device. Its showing that the data type is “4Q FP P...
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
stephen_cullen_
stephen_cullen_
Explorer
Posted: ‎2016-09-28 01:42 AM
4325
  • pm5100_5300
Hal_Etheridge
Hal_Etheridge Champion
Champion
Posted: ‎2016-09-28 02:21 PM
The standard modbus format type required should be "PF32".  From looking at the modbus formatting code this seems to do a similar calculation for PF_Val as described above.
If the MDI does not support this format then use the IEEEFloat type and then hand edit the generated .xml file to change from IEEEFloat to PF32 for those registers.
