Hello friends
I'm using the Alert Module to send emails, everything went right but it printed a UTC datetime. So my question is if it's possible to change this to local time (actually GMT -5 Peru).
Thanks.
Posted: 2013-08-08 10:23 AM
So after alittle digging I found out that your choices for time are UTC or by using the %t characters you can have UNIX time.
However I did find a workaround in a tech support article that may fill your needs. I have pasted it below for your reference.
What you need to do is Link the Hour, Minute and Second Clock module output registers to Source2, 3 and 4 respectively of the Alert Module (if you use these sources, use the next three available ones). Then your module would look something like this:
Your message ie: Alert on %N1 (input 1) value: %V1 Local Time:%V2:%V3:%V4
and the email you get would read:
Message:Your message ie: Alert on Vll avg (input 1) value: 1039.45 Local Time:8:59:7
Time:11/01/2006 16:59:07 UTC
Priority:128
Owner:
Tag1:
Tag2:
There is no way to mask the UTC reading, but in this case, you would at least get both times (UTC and Local).
Posted: 2013-08-08 10:28 AM
Also this may be of relevance to members of the Hardware Power Monitoring forum. If you get a chance move the question there for others to view.
It can be found here:
https://powersolutionscommunity.schneider-electric.com/community/power-monitoring-hardware
