Continue
  • My Subscriptions
  • Events
Fail to reset meter(PM5320) readings via Modbus TCP
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Fail to reset meter(PM5320) readings via Modbus TCP
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2022-06-10 12:47 AM
7
8774
I am sending reset command (2009 & 2020) to the meter via Mod-bus TCP with reference to the FAQ.
However, the meter have nothing happened and I receive [0,30659] when I try to check registers [5125-5126].
Can anyone tell me how to fix it?
Also, is there any command that I can reset all readings at once?
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2022-06-16 11:02 PM
Hi @Anonymous user
Please arrange remote session in team viewer or teams my email ID: ramasamy.narashimman@se.com
Ramasamy N
Replies 7
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2022-06-13 04:49 AM
6
8734
Hello @Anonymous user
Can you share the Wireshark traces when the commands 2009 & 2020 sent to the meter and response received form the meter for analysis?
You can use the ION setup to reset all (navigate to Meter resets -> Meter initialization) parameters.
Ramasamy N
Posted: ‎2022-06-14 12:01 AM . Last Modified: ‎2022-06-14 01:55 AM
8705
I have tried, but unable to get same fail result. However, the first register of reply are both 0.
@Ramasamy_N
modbus.txt
modbus_2.txt
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2022-06-14 02:31 AM
8695
Hi @Anonymous user
The meter will accept the Modbus energy reset command if we follow the command structure as below,
Register1 5000 = 2020
Register2 5001 = Semaphore received from the register 5680
Can you please try once in ION setup and share the observation?
Ramasamy N
Posted: ‎2022-06-16 08:39 PM
8613
Hi @Ramasamy_N
Both Min/Max and Energy are required reset.
I cannot execute reset via ION setup.
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2022-06-16 10:06 PM
8606
Hi @Anonymous user
You will get this error "unable to gain device setup access" if the meter HMI entered in to the setup menu.
Keep the meter HMI in summary page and reset the energy from ION setup.
Please make sure the device ID configured as 255. PM5320 device properties in ION setup.JPG
Ramasamy N
Posted: ‎2022-06-16 10:59 PM
8600
Hi @Ramasamy_N
I wait for while and retry again but it return a unsuccessful.
Here attached is my print-screen and wire-shark captures.
ION_0617a.txt
ION_0617b.txt
Ramasamy_N
Ramasamy_N Champion
Champion
Hi @Anonymous user
Ramasamy N
