I have several meters at a site. I have been trying to download the files using a SFTP software. I have tried WINSCP and FileZilla and in both cases, I almost always get errors.
For the FileZilla; I get an Open Read failure and the transfer fails.
For the WIN SCP I get this error:
General failure (server should provide error description).
Error code: 4
Error message from server:
Common reasons for the Error code 4 are:
- Renaming a file to a name of already existing file.
- Creating a directory that already exists.
- Moving a remote file to a different filesystem (HDD).
- Uploading a file to a full filesystem (HDD).
- Exceeding a user disk quota.
This makes using the FTP transfer mostly useless.
Hello @Paul_Crouch ,
Have not heard back form you on this topic. If still having trouble please reach out to technical support. Cannot tell from description if something in configuration, system or other. Hopefully the setting suggestions will help your customer.
Charles
Hi @Paul_Crouch
Please note that, in ION9000, as of firmware V2.2.1, meter only supports secure file transfer protocol (SFTP). FTP and Telnet protocols are no longer supported.
Ensure that the protocol and ports are enabled:
You could check for a direct connection if possible, especially if FTP (on meters with older firmware) or SFTP is being blocked by the network.
Best Regards,
-Mehran
L3 Expert Advanced metering
May need a bit for information about your system. What version of WinSCP do you have? What firmware version?
Some settings that may help.
Open Preferences in WinSCP
Under Transfer -> Endurance
Charles
Hi Charles,
The FW on the all the meters is 2.002, so it is out of date. Thought I had updated, but had not yet.
I can download directly from the meter using ION setup.
I will update the FW on at least on of the meters to see if that helps in any matter.
I have changed the WINSCP settings as suggested and will see what happens.
Any update about using sFTP?
Charles
Charles
