Continue
  • My Subscriptions
  • Events
FAQ Vigilohm System How to Operate a Vigilohm System?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • FAQ Vigilohm System How to Operate a Vigilohm System?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Madleen_Laclef
Madleen_Laclef Mentor
Mentor
Posted: ‎2015-06-10 06:37 AM . Last Modified: ‎2020-04-20 06:03 AM
From the link below, access a document with some FAQ around the operation of a Vigilohm System:
How to Operate a Vigilohm System _ FAQs.docx - Box
This document includes the following questions:
- On an XL3xx, when I navigate from one toroid to another using the « increment » button, there is one toroid which is skipped. I cannot access the measurements for this toroid.
- I did the following test : I disconnected one toroid from the XL3xx or the XML3xx. But I did not see the message “tor” in the XL3xx display, which is supposed to appear and warn me that one toroid is disconnected. Why is that?
- How can I acknowledge intermittent faults on the XL3xx ?
- Why do the XL3xx or XML3xx display « .. » instead of showing the measurements per feeder? In the manual, it is mentioned that this means “measurement impossible, the CPI is a fault and the fault is not one the channel selected”. What does it mean exactly?
- On XL3xx or XML3xx, what is the meaning of “A3x” (A31, A32….)?
- In my system, the Insulation Monitoring Device is indicating a fault. But none of the XL3xx locator indicates a fault. What is the explanation?
  • Insulation Monitoring
Tags (3)
  • faq
  • system
  • vigilohm
Replies 0
