Hi!
I am looking at the ION8650 modbus protocol document on page 82 appendix B, the information shown there is to read a recorder through the modbus protocol, perform a routine and it worked but when trying to perform the same query on a PM8000/ION9000 it did not work.
Is there any document that contains the necessary information to perform these same queries via modbus?
Hello @Roberto_Ruiz
PM8000 and ION9000 do not support reading data recorders through Modbus at this time. Some modbus registers have been reserved for a possible future feature.
Charles
Hello @Roberto_Ruiz
Charles
Hello @Charles_Murison , Thank you for your prompt reply.
I was testing with the Log Export Module, what I know is that it can send via email the selected recorder every so often in an xml file, but I can not get the meter to connect to my SMTP server, because I do not know where to put the authentication credentials, I saw another post and they said a simple SMTP, but my SMTP server asks me the credentials strictly. Could you help me to configure them? I have only managed to see the configuration to put the server address, but I do not see the credentials. Or are these options enabled by license and how can I check if my license is valid?
Hello @Roberto_Ruiz ,
The Log export module for ION9000 and PM8000 meters does not support authenticated SMTP. You would need to reach out to your local sales representative to request they create a feature request. Feature requests from all over the globe get funneled and the team at Schneider use a number of metrics to determine priority and order for features to get put into future firmware. Long way to say even if feature request is created not a guarantee will be in a future firmware.
Charles
Hi @Charles_Murison ,Thank you for your suggestion.
I set up an SMTP server as instructed and it works. An email arrives with an attachment with an “mma” extension, I think it is the xml you mention. I would like to know if there is any documentation about the structuring of the “mma” file in order to be able to interpret it correctly and avoid errors with it.
I do not remember any specific document on the structure of the file but I remember it being pretty obvious when looking at contents of the file.
Charles
