Continue
  • My Subscriptions
  • Events
EDS files for PM5560 and PM5320
Metering & Power Quality
  • EcoStruxure Power & Grid
  • EDS files for PM5560 and PM5320
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
ShaunTaylor
ShaunTaylor Contributor
Contributor
Posted: ‎2021-02-11 04:18 AM
8541
Hi, my customer is needing to enable his Schneider PM5560 and PM5320 meters for comms with Rockwell ethernet protocol. For this they need the EDS files.
I have managed to find the EDS for the PM5560 in the latest firmware zip. However it appears to be missing from the latest PM5320 fimware zip.
Could someone direct me to the file please?
Many thanks
Shaun
  • PM5000
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2021-02-11 06:50 PM
4
8530
Hello Shaun,
PM5300 supports only the Modbus TCP and BACnet IP protocols. It does not supports Ethernet/IP protocol.
We don't have the EDS file for PM5320.
Ramasamy N
Tags (3)
  • Hi
  • my customer is needing to enable his Schneider PM5560 and PM5320 meters for comms with Rockwell ethernet protocol. For this they need the EDS files.
Replies 7
Charles_Murison
Champion
Posted: ‎2021-02-11 09:08 AM
@Ramasamy_N , are you able to help Shaun?
Charles
Ramasamy_N
Ramasamy_N Champion
Champion
4
8530
Hello Shaun,
Ramasamy N
Tags (3)
  • Hi
ShaunTaylor
Contributor
Posted: ‎2021-02-12 12:27 AM
Thank you for the clarification Ramasamy. I had not spotted the distinction previously.
Posted: ‎2022-11-25 02:18 AM
7695
Hello Ramasamy,
Do you know how the PM5560 generic module Assembly input on the Rocwell Logix tags should be set up? is it DINT, INT or SINT, or anything else?.  I use a generic module, and I can see the data is exchanged. (Implicit exchanges). But, it's not same as per actual data shown at the PM5560 parameter. i.e current.
Any help will be appreciated. Thank you
Best regards
Aep
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2022-11-25 03:53 AM
1
7688
Hello Aep,
The generic module Assembly input to be set as REAL.
Please refer the attached screenshot of configuration for more details.
PM556x with RS logix.docx
Posted: ‎2022-11-25 07:05 PM
Hello Ramasamy,
Just changed the comm format to REAL, and then, bam! it's working. it showed the correct number. 🙂
so, thank you so much for your help!!
Best regards
Rahman
Patil8639
Patil8639
Explorer
Posted: ‎2026-08-19 08:15 AM
We have rockwell plc with PM5560 meter on ethernet ip .i want eds file and mapping detail
