Download Events from a non ethernet based IN7550
Metering & Power Quality
Send InviteCancel
2024-06-0312:24 PM
Is it possible to download power events recorded on *stand-alone non-ethernet based ION7550 direct to a laptop via Modbus Master such as an EGX150 or Panel Server.
No, the event log cannot be read using Modbus protocol. If able to connect directly to meter's serial port to a computer serial point you might be able to use ION Setup to read the data.
If going through a gateway, you would need a protocol agnostic gateway device or one that supports the ION protocol. EGX150 I believe supports ION protocol with some configuration changes. Panel Server I believe does not.
