Continue
  • My Subscriptions
  • Events
Display VLL Waveform Capture in Web Portal
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Display VLL Waveform Capture in Web Portal
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
PowerLogic ION9000
eRicC
eRicC
Explorer
Posted: ‎2023-10-06 03:02 AM
3445
Hi there,
There is an application request to capture waveform in VLL in addition to the default of capture waveform in VLN when wiring in WYE connection of a ION9000.
As such, a new set waveform recorder modules had been added, with the inputs linked to Data Acquisition Module's output of V12, V23, V31.
The datalog viewer had been duplicated from default diagram to include the phase-to-phase waveform.  The waveform is captured successfully and able to see it under Plot Display; Harmonics Analysis and Phasor Diagram in Vista or ION Setup.
However, an error of "There was a problem processing your request." is shown when opening the same phase-to-phase voltage waveform in web portal (while all good when opening the default V1, V2, V3 waveform in the same event.
The screen captures are attached and your guidance is much appreciated so that the captured phase-to-phase waveform can be displayed in webportal like the default.
Thanks.
  • Thumbnail of PowerLogic ION9000
    PowerLogic ION9000
View products (1)
  • ION9000
Tags (5)
  • phase to phase voltage
  • vll
  • waveform
  • waveform capture
Charles_Murison
Champion
Posted: ‎2023-10-06 10:37 AM
3441
Hello @eRicC ,
You will likely have better success if you post this question on the PME forum rather than metering forum.
Charles
Charles_Murison
Champion
3441
Hello @eRicC ,
Charles
eRicC
eRicC
Explorer
Posted: ‎2023-10-08 08:45 PM
Thanks for the advice, Charles!
