Continue
  • My Subscriptions
  • Events
Current Transducers
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Current Transducers
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
tneil
tneil
Explorer
Posted: ‎2025-03-03 06:35 AM
764
Current Transducers
Which part number for current transducers is recommended to use with PM5560.  The current transducers need to be for 460 V and each have a rating of 2000/5 Amps.
Tim
Charles_Murison
Champion
Posted: ‎2025-03-03 09:17 AM
Hello @tneil ,
I moved your message to the metering specific forum. Please note that there is a difference between Current Transducer and current transformer. A Transducer any device that converts a current measurement into another form of signal such as voltage. A transformer will output the signal as current.
Please note that PM5560 meters will only work with current transformers. As for recommendations, there are a few options and a lot will depend on accuracy needed, the shape and size of the conduit the meter is intended to monitor. There are other factors as well. I recommend reaching out to your local Schneider sales team to help determining what you need.
Charles
Charles_Murison
Champion
Hello @tneil ,
Charles
