Continue
  • My Subscriptions
  • Events
Circuit Breaker Micrologic Accuracy
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Circuit Breaker Micrologic Accuracy
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
edward_lim_uon_
edward_lim_uon_
Contributor
Posted: ‎2016-06-20 11:22 PM
2
1978
I understand that Micrologic accuracy is impacted at low load conditions. Due to our customer querying the difference between master meter and submeters (Micrologic) kWh, we discovered that one of the circuit breaker kWh had a difference of up to 40% because of low load for the the rated breaker size.
Can anyone explain why the kW per phase calculated shows 0 kW during low load conditions when there is current measurement. Is this a limitation in the Compact NS Micrologic E algorithm?
It is a 1250A breaker.
We have both ION6200 and Micrologic on the same feeder:
Best regards
Edward
Tags (3)
  • accuracy
  • circuit breaker
  • micrologic
edward_lim_uon_
edward_lim_uon_
Contributor
Posted: ‎2018-03-21 01:47 AM
Grant,
Thanks for your reply.
The Micrologic accuracy is only guaranteed when current is greater than 10% of nominal current.
Meter and CT is definitely better than Micrologic and from my experience iEM3xxx KWh meter readiings are better than the IOn6200 at very low load.
For NS breakers kW reading only accurate greater than 30kW.
NSX breakers:
Grant_IPACS
Grant_IPACS
Mentor
Posted: ‎2018-03-20 09:55 AM
Edward,
I believe the micrologic metering is essentially leveraging protection CT's to derive these energies for display, and may not be accurate at low load (it takes about 30% load for them to be 'excited' enough) to be within accuracy.  Whereas the 6200's and a good set of CT's would be much more accurate at low load.
HTH
Grant
Regards
Grant
edward_lim_uon_
edward_lim_uon_
Contributor
Grant,
NSX breakers:
