Continue
  • My Subscriptions
  • Events
Active Power Filter - Internal Components
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Active Power Filter - Internal Components
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
CJx
CJx
Explorer
Posted: ‎2025-09-10 12:25 AM
943
Hi everyone,
I'm looking for a diagram of the internal components for an Active Power Filter. Does anyone have a technical drawing or a similar diagram they could share? I'm trying to understand the layout and how everything is connected.
Thanks in advance for any help!
  • Power Quality
Swapnil
Swapnil Contributor
Contributor
Posted: ‎2025-09-10 08:39 PM
1
928
Hello..
As per your request regarding the internal component document, please note that it is classified as confidential and governed by company policy. Therefore, it is intended strictly for internal use and cannot be shared externally.
Best regards,
Swapnil
Swapnil
Swapnil Contributor
Contributor
1
928
Hello..
Best regards,
Swapnil
CJx
CJx
Explorer
Posted: ‎2025-09-10 11:27 PM
I would like to confirm if an active harmonic filter (AHF) or active power filter (APF) contains capacitors. If so, is it safe to energize a unit that has been in storage for more than two years?
If not can you suggest a energization procedure?
Thank you.
Swapnil
Swapnil Contributor
Contributor
Posted: ‎2025-09-16 02:52 AM
Hello CJx,
Yes, capacitors are present in the AHF system. If the systems have been stored for more than 2 years in ideal conditions without being charged, then capacitor reforming is required before commissioning.
If you still need further clarification, the correct approach is to raise a BFO case through the country Customer Care team for formal support and documentation.
Thank you,
Best regards,
Swapnil Gujar
