Continue
  • My Subscriptions
  • Events
7550RTU Pulse input, minimum voltage for correct operation ?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • 7550RTU Pulse input, minimum voltage for correct operation ?
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2016-10-19 01:44 AM
1260
Does anybody know what the minimum voltage that the 7550RTU can take on a digital input from a pulse meter ?
The manual states external supply of maximum 130VDC but what is the minimum for the input to operate correctly ?
Tom_Stevenson
Tom_Stevenson Champion
Champion
Posted: ‎2016-10-19 08:38 AM
1222
Christopher Ailey
DanL
DanL Champion
Champion
Posted: ‎2016-10-20 10:56 AM
The ION7550 digital inputs are internally excited to -30Vdc with a high-impedance source making them most suitable for simple closed-contact sensing (zero volts).
Any (low-impedance) voltage source connected between 0V and 130V will be recognized as closed.
Hope this helps
Dan
sesa54412_bridg
sesa54412_bridg Contributor
Contributor
Posted: ‎2016-10-21 05:10 PM
Hi Richard,
Dan Loewen has provided a good description which should answer your question.
Nonetheless, here is a picture in case it is still not clear:
Kind Regards,
Chris.
