84693members
354073posts
Error Generating USB Programming files
Machine Automation Forum
sardila
320
I recently Updated the EcoStruxture Machine Expert  version to the latest one 1.4.0 and the target bios to 668.12 firmware version.
Now, I am getting errors traying to generate the USB programming files:
File C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_7IO\PARAM.DAT and C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_7IO\PARAM.RAW correctly generated
Error generating file C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_7IO\PARAM.BIN
USB folder generated: C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_7IO
File C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_18IO\PARAM.DAT and C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_18IO\PARAM.RAW correctly generated
Error generating file C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_18IO\PARAM.BIN
USB folder generated: C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_18IO
Anyone have had this issue before?
I much appreciate any suggestion, Thanks.
FedericoM
Lieutenant Lieutenant
Lieutenant
303
Re: Error Generating USB Programming files
this is a known bug of version 1.4.0 with target 7/18 I/O.
You can fix it with the patch you can find at this link:
https://schneider-electric.box.com/s/svi3uam9raimwf51srhf70zv3idbup10
3 Replies 3
Bastian_Schmitz
Commander Commander
If you update the target in a project and you get this error try the function "Refresh current target"
Tags (2)
FedericoM
Lieutenant
304
sardila
Thanks, I much appreciated it.
The bug was fixed!
