84244members
353344posts
BACnet Addons Library for Ecostruxure Machine Expert HVAC
Machine Automation Forum
Anawat
4582
I'm working on M172 controllers and need to use BACnet protocol.
Anybody know where can i download BACnet Addons Library for Ecostruxure Machine Expert HVAC?
PierpaoloA
Schneider Alumni (Retired)
10
4574
Re: BACnet Addons Library for Ecostruxure Machine Expert HVAC
Hi, you can download the BACnet Addons library for ESME HVAC from this link: https://schneider-electric.box.com/s/7r58enj2e5wk3i08v37jyho5apsy445j
Please feel free to reach out for any question you might have in this regards.
Pierpaolo
Pierpaolo Armeli
Technical Expert Community Facilitator & HVAC Expert
PierpaoloA
Hi Anawat,
As discussed, the best in this case is to use a workaround, as by using a mirror point and alarm object in EBO system.
Pier
11 Replies 11
PierpaoloA
10
4575
Pierpaolo
Pierpaolo Armeli
Anawat
@PierpaoloA
Thank you very much.
Anawat
4517
Hi Pier,
I am able to discover MP172 BACnet device and objects into EBO.
i have one issue about alarm and reset text Message of BI object. These are not propertied in ESME to add.
PierpaoloA
4501
the string fields can be edited only from the PLC (they are read-only)
You can double check on the PICS which properties are implemented (https://www.bacnetinternational.net/btl/index.php?m=266) - they are in line with the AAC profile.
Please contact me directly to investigate further and then we can report here the findings.
Thank you.
Anawat
I got it. Thank you.
PierpaoloA
PierpaoloA
Hi Anawat,
Pier
VaidasM
1654
we are using Bacnet Library 2.3 version within M172 controllers for AHU application and we experience random disconnections from the network. We've moved Bacnet task from background to timed task (we believe their priority is higher), also made longer timeouts on Bacnet line in AS-P, situation got a lot better, but not perfect - disconnections still occurs. Do you have any ideas ?
Thank you.
Anawat
I'm not found this error before. You can try to check the below link. It might be help.
Schneider M172 PLC and AS-P BACnet communication problem.
jf_graphen_pl_b
275
Hello Pierpaolo,
I 've the same kindly request but concerning  Modbus. Would you like to send  al link to MODBUS Addons Library for Ecostruxure Machine Expert HVAC?
Thanking in advance,
Artur
Ismet_S
Ensign Ensign
Modbus Addons Library for Ecostruxure Machine Expert HVAC
By default the Modbus Addon "ModBUS_Addons_M172P_O.plclib" is under the folder :
"C:\Program Files (x86)\Schneider Electric\EcoStruxureMachineExpertHVAC\Catalog\FreeAdvance\PLC"
BR
