"Read-only because object refers to a standard file" when editing Menta from Workstation
  • "Read-only because object refers to a standard file" when editing Menta from Workstation
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • sesa150555
    sesa150555
‎2018-09-07 06:57 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:44 AM
  • "Read-only because object refers to a standard file" when trying to change Menta application (.mta file) from TAC workstation.
  • "File object is locked by another application" when trying to edit a Menta application (.mta file) (file is not marked as reserved)
TAC Vista
  • Menta
  • Workstation
If a standard file is used, it is not possible to edit the "local" Menta file. Other causes are explained in "File object is locked by another application" error when trying to edit Menta file.
If the referenced file is supposed to be a standard file, locate and edit the file referenced.
If the referenced file is not supposed to be a standard file:
  1. Click on the more button under the MTA tab in the properties for the device.
  2. Uncheck "Reference standard file object.
  • 4762
