HID card formats are supported by Continuum
  • HID card formats are supported by Continuum
  • RandyDavis
    RandyDavis
  • AbeMeran
    AbeMeran
  • Omaelk
    Omaelk
  • Alan_Wood
    Alan_Wood
‎2018-09-06 01:24 PM
Last Updated: Janeway Omaelk ‎2022-10-19 03:01 AM
There is a need to know which card formats are supported by Continuum
Andover Continuum
  • Access Control
  • Continuum Cyberstation
There are many different card formats available from HID, so there is a need to know which formats that Continuum allows.
Here are the formats that HID offers:
  1. 26-Bit Format: H10301
  2. HID Proprietary 37-Bit Format: H10302 ****
  3. HID Proprietary 37-Bit Format with facility code: H10304
  4. Corporate 1000 Formats
  5. HID Long Format Card Programming
  6. OEM Proprietary Formats (i.e. Continuum 37)
  7. 35-Bit Card Format
Formats 1, 4, and 6 above are supported natively
We support all the other formats (as custom cards) so long as the format does not exceed 64-bits and the format can be supplied or understood. (i.e. start/end bit of the site code, card number, etc.)
****IMPORTANT
Continuum supports a maximum of 32 bits for the Card Number field, any format above, such as the H10302, that defines more than 32 bits for Card Number field will only work if the card number range used at the site is between 1 and 4,294,967,295, any card number above 4,294,967,295 will NOT be read correctly by the controller.
A possible solution for this limitation is to use the Extended Custom Cards feature supported ONLY in the ACX5720 and ACX5740 controllers.
More information about Extended Custom Cards
https://community.se.com/t5/Building-Automation-Knowledge/Extended-Custom-Wiegand-features-available...
Tags (2)
  • 5977
  • AbeMeran22
50% helpful (1/2)
