Use a TAC Xenta OP with a Xenta 100-series controller
  • Use a TAC Xenta OP with a Xenta 100-series controller
  • PeterEdvik
    PeterEdvik
  • CraigEl
    CraigEl
  • MikaelKrantz
    MikaelKrantz
  • Cody_Failinger
    Cody_Failinger
  • SESA116857
    SESA116857
‎2018-09-07 02:34 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-28 05:21 PM
How can the TAC Xenta OP be used with a TAC Xenta 100-series controller?
  • How does the OP identify which TAC Xenta 100 controller it's communicating with?
  • Which OP mode should be used?
TAC Vista
  • TAC Xenta OP
  • TAC Xenta 101
  • TAC Xenta 102
  • TAC Xenta 121
  • TAC Xenta 122
The TAC Xenta OP panel allows access to input and output signals from a TAC Xenta 100-series controller. Identification of the specific controller is achieved via a Service Pin message.
  • If connected directly to a TAC Xenta 100-series controller or a STR100-series device attached to it, the controller automatically sends a Service Pin message.
  • If connected elsewhere on the network, you may need to manually press the Service Pin on the desired controller.
For troubleshooting connectivity issues, refer to:
“No Answer” on an OP when connecting to a Xenta 280/300/400
1. Configure the TAC Xenta OP
  1. Plug in the TAC Xenta OP.
  2. Hold Back and Enter for 3 seconds to access the OP Service Menu.
  3. Scroll to Option 10: OP Mode.
  4. Set “Xenta 100” to ON using the + key. Press Enter.
  5. Set “Mode” to TAC using the + key. Press Enter twice to restart the OP.
2. Connect to a TAC Xenta 100-series Device
  • Plug the OP into the OP jack on the TAC Xenta 100 controller or a connected STR100 device.
  • When prompted “Press to access Xenta 100”, press Enter.
  • At “Connecting to Xenta 100…”, wait or press the Service Pin on the controller.
  • Press Down to proceed.
3. View and Modify Network Variables
  • At the NV Index? prompt, use +/- to select the desired network variable index.
  • Press Enter to view the signal.
If the value is an input:
  • Use +/- to modify the value.
  • Press Enter to accept.
If the signal is a bit-based application option:
  • Press Enter to navigate between bits.
  • Use + to change the bit value.
  • Press Enter to confirm.
Tags (3)
  • 5003
  • MikaelKrantz20
  • MikaelKrantz25
