SmartStruxure Lite shows offline in StruxureWare Building Operation
  • SmartStruxure Lite shows offline in StruxureWare Building Operation
  • CraigEl
    CraigEl
  • sesa194431
    sesa194431
‎2018-09-11 04:25 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 09:17 PM
When the EWS interface is created, the Status show "online". However, after clicking on the Hardware > EcoStruxure Web Service > SSLite, the Status will go offline.
EcoStruxure Building Expert, EcoStruxure Building Operation
  • StruxureWare Building Operation 1.3 and above
  • SmartStruxure Lite 2.7 and above
  • EcoStruxure Web Services
Make sure the SOAP Endpoint field says "ews" and not "EWS". Lua program is a case sensitive program.
Change the SOAP Endpoint field to "ews".
For firmware version support in EWS, see Firmware versions to support EcoStruxure Web Services (EWS) in SmartStruxure Lite MPM Controllers.
Labels (2)
  • EcoStruxure Building Expert
Tags (2)
  • 13717
  • can2go
