SHD100 / SHD101 - Humidity Sensors can give a DC voltage signal of greater than 10 Volts.
  • SHD100 / SHD101 - Humidity Sensors can give a DC voltage signal of greater than 10 Volts.
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 02:12 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-08 06:17 PM
When using SHD100 or SHD101 humidity sensors with a BAS 2800+ Outstation or Sigma Controller, the sensors may output a DC voltage exceeding the expected 0–10V range. This can cause the controller to display a default or erroneous value.
Satchwell BAS & Sigma
  • BAS 2800+ Outstation
  • Sigma Controller
  • SHD100 / SHD101 Humidity Sensors
The sensors are capable of producing a DC voltage signal greater than 10V. When this occurs, the controller may interpret the signal as out-of-range and revert to a default value, potentially triggering alarms or incorrect readings.
To prevent out-of-range errors and ensure accurate readings:
  1. Add a Series Resistor
    Install a 10K ohm, 0.1% tolerance resistor in series with the 0–10V signal line. This helps limit the voltage and protect the input circuitry.
  2. Create a Lookup Table
    In Sigma or BAS 2800+, configure a lookup table with the following values:
    Input (mV) Output (%)
    0 0
    83335 100
    100000 100
    This table allows the system to interpret voltages up to 11.335V without triggering an out-of-range alarm.
  3. Apply the Table
    Assign the lookup table to the analog input object. Then download both the object and the table to the Outstation or Controller.
Outcome
With this configuration, the system will tolerate sensor outputs up to 11.335V, ensuring stable operation and avoiding false alarms.
Labels (2)
  • Field Devices
  • Satchwell BAS & Sigma
Tags (2)
  • 4589
  • CraigEllis25
