Remote Desktop Connection issues When Starting Vista Server
  • Remote Desktop Connection issues When Starting Vista Server
  • CraigEl
    CraigEl
  • PeterLarsen
    PeterLarsen
  • sesa145087_brid
    sesa145087_brid
  • sesa150561
    sesa150561
‎2018-09-10 06:31 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-21 10:10 PM
Error: 8000401a
Retrieving the COM class factory for component with CLSID {2B768E20-89F2-11D2-99FD-00104B6D2299}
failed due to the following error: 8000401a.Server process could not start because the  configured
identity is incorrect. Check username and password. (Exception from HRESULT: 0x8000401A).Code: -2147467238
When starting Vista Server, a fatal error happens: TACOS: COM Initializing failed, error code: -2147417831
TAC Vista
  • Remote desktop
  • Windows 2008 Server or Windows 7
When using Remote Desktop with a Windows 2008 Server and disconnecting, the TACOS process may end up in a "sandbox" and can not be reached by other people trying to log in remotely. Or, the Vista Server can't be started.
The attached Tacos RDP Disconnect contains scripts that will disconnect a Remote Desktop session back to the physical session if tacos.exe is running. If tacos.exe is already running on the physical session or is not running at all, nothing happens.
Tacos_RDP_Dicsonnect_v1-MIJA1.rar
Tags (2)
  • 7186
  • PeterLarsen22
