Reader beeps continually when connected to the door controller
  • Reader beeps continually when connected to the door controller
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • sesa145087_brid
    sesa145087_brid
‎2018-09-10 05:01 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 06:59 PM
The card reader beeps continually when connected to the door controller with the Sounder cable connected.
TAC INET
I/NET
There may be several causes for this situation:
  1. The door which this reader belongs to isn't configured.
  2. The polarity setting of the reader beeper isn't correct.
  3. This reader port is damaged due to certain cause.
The following steps need to be followed:
  1. For cause 1, configure the door and reader in Door parameter.
  2. For cause 2, click "Sounder" button in the Door parameter window and change the "Polarity" setting correctly. Usually change from "High" to "Low".
  3. For cause 3, send the door controller to repair.
For how to set up a beeper in I/NET, refer to How to use the Beeper of the Card Reader in I/NET.
  • TAC INET
  • 6754
