Planning for Continuum LAN Upgrade
  • Planning for Continuum LAN Upgrade
  • CraigEl
    CraigEl
  • GavinHe
    GavinHe
‎2018-09-07 12:24 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-26 03:40 PM
There is a lack of clarity regarding the necessary preparation steps for upgrading a Continuum LAN system. Inadequate planning can lead to compatibility issues, data loss, or system downtime.
Andover Continuum
  • Continuum Cyberstation
  • SQL Server
Upgrades without proper preparation may result in:
  • Software and hardware incompatibility
  • Data integrity risks
  • Extended system outages
To ensure a successful upgrade, follow these best practices:
1. Review Compatibility Matrices
  • Consult the Continuum Compatibility Matrix and Continuum Video Compatibility Matrix.
  • Use these tools to plan upgrades for all supporting software and hardware.
2. Verify Software Compatibility
  • Ensure that .NET and SQL Server versions are compatible with the target Continuum version before starting the upgrade.
3. Update Controller Firmware
  • Older CX controllers (firmware ≤ 1.500029) use a different handle algorithm and must be upgraded prior to the LAN upgrade.
  • Other controllers can be upgraded after the front-end systems are updated.
4. Assess Hardware Requirements
  • Evaluate all current computer hardware, especially the Continuum Database Server.
  • Choose hardware based on customer needs and system requirements.
  • This decision should involve engineering expertise and likely the customer’s IT department.
5. Consider Off-Site Preparation
  • When deploying a new database server, it may be beneficial to build and prepare the Continuum server and database off-site.
6. Engage Experienced Engineers
  • The upgrade process is complex and should be led by an engineer experienced in Continuum LAN upgrades.
  • This ensures proper execution and provides mentorship for technicians involved in future upgrades.
Tags (2)
  • 4477
  • GavinHeward25
