Lost license Entitlement ID Vista 5.x
  • Lost license Entitlement ID Vista 5.x
  • PeterLarsen
    PeterLarsen
  • SESA150559
    SESA150559
  • Sacco
    Sacco
‎2018-09-06 01:59 PM
Last Updated: Administrator CraigEl Administrator ‎2023-07-19 06:55 PM
Lost Entitlement ID when you want to rehost/return/modify existing license.
TAC Vista
Vista 5
When a rehost/return/modify of an existing license is required, the Entitlement ID is required.
Contact support and provide the current Host ID (PC MAC address) /Dongle ID used, alternatively the current license file or Fulfillment ID.
The directory that the License file is located in can be found using the License Setting tool.
Support will then provide the Entitlement ID for license in question.
The Entitlement can also be found providing the original Purchase Order ID to the order entry department at 1-888-444-1311 if in the continental US.
Tags (2)
  • 4848
  • PeterLarsen23
100% helpful (2/2)
