I/NET Seven Windows fields not aligning correctly on workstation's display
  • I/NET Seven Windows fields not aligning correctly on workstation's display
  • RobertAndriolo
    RobertAndriolo
  • CraigEl
    CraigEl
  • sesa145087_brid
    sesa145087_brid
‎2018-09-10 02:34 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:35 PM
I/NET Seven running on a Windows 7 computer that has an issue with fields not aligning as shown below:
TAC INET
I/NET Seven
This is caused by increasing the text size of the workstations display from the default setting of 100%.  It will occur on any Operating System not just Windows 7.
Make sure the Display settings Text setting is at the "Default setting (100%)".  If it's any larger then it will distort the text and editor titles will be miss aligned with the text displayed in the summary / editors.  You change this as follows:
Windows 7:
  1. From the Control Panel: - Select Appearance and Personalization
  2. Under the heading Display select “Make text and other items larger or smaller”
  3. Change setting is set to Smaller – 100% (default).
  4. You will then need to log off and then back in for these changes to take affect.
If this does not resolve the issue, refer to Windows Alignment Issue for I/NET display.
Windows XP / Server 2003:
  1. From Control Panel: Double-click on Display
  2. Select the Settings tab (top right)
  3. Click on the Advanced tab
  4. Within the Display section select the "Normal size (96 DPI)" from the DPI setting drop down box.
  5. A restart of the workstation may be required to apply these changes.
  • TAC INET
  • 5906
