I/NET CD Key and software revision
  • I/NET CD Key and software revision
  • Cody_Failinger
    Cody_Failinger
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 02:18 PM
Which CD Keys can be used with which version of I/NET Seven Software?
TAC INET
I/NET Seven - all revisions.
Need to know which CD Key can be used with which version of I/NET CD
The I/NET CD Key is comprised of
  • User Name
  • Site Name
  • Key; provided in the format XXXX-XXXX-XXXX-XXXX-XXXX.
The key provided above is a 20 character key, segregated into five 4 character sets.  The second set of four characters (shown in bold and underlined above) and using the table below, will help identify which version of I/NET Seven Software works with which CD-Key:
I/NET Seven Version
CD Key
I/NET Seven 1.xx
XXXX-D71R-XXXX-XXXX-XXXX
I/NET Seven 2.00 to 2.31 (Excluding 2.30)
XXXX-E71R-XXXX-XXXX-XXXX
I/NET Seven 2.30 (Only)
XXXX-F71R-XXXX-XXXX-XXXX
I/NET Seven 2.4x
  • TAC INET
  • 4285
