Host number conflict on a computer with dual Network Interface Cards (NIC)
  • Host number conflict on a computer with dual Network Interface Cards (NIC)
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • sesa145087_brid
    sesa145087_brid
‎2018-09-11 07:04 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 06:41 PM
When there are dual NICs on the computer, you will get host number conflicting error. The IP address causes this conflict is just the local IP address.
EcoStruxure Building Operation, TAC INET
  • I/NET prior to Version 2.44a
  • Win 7 or higher OS
When there are two NICs on the computer, I/NET needs to know which NIC is used for communication. I/NET support for dual Network Interface Cards (NIC) can be used for dual NIC configuration for I/NET. But under Win 7 and higher OS, wireless NIC can't be recognized in I/NET, which makes it impossible to choose wireless NIC to be used for I/NET. In the I/NET configuration, it just shows 0.0.0.0.
I/NET will fix this issue in the new release. For I/NET prior to version 2.44a, there are two workarounds for this issue currently:
  1. Refer to I/NET support for dual Network Interface Cards (NIC) to choose onboard NIC to be used for I/NET communication.
  2. Disable onboard NIC or just disconnect it from the network. Then you will see the option for choose NIC for I/NET communication will be grayed out. That will force I/NET to communicate with wireless NIC.
Remember to reboot I/NET I/O server after this to make it take effect.
Labels (2)
  • TAC INET
  • 15859
