Graphic values not updating in a network that includes a Xenta 7XX
  • Graphic values not updating in a network that includes a Xenta 7XX
  • Benji
    Benji
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
‎2018-09-10 03:18 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:07 PM
Values are coming into Vista without issue but do not update on the graphics in the Xenta 7XX.
TAC Vista
  • Workstation
  • Graphics
  • Xenta Server 701, 711, 721, 731
If there is a Xenta Server in the database, when connection objects are not used to bind values between a controller and a Menta program in the Xenta Server, this graphic update can occur.
It can also be because of the XIF for a device being formatted incorrectly. If the procedure below doesn't solve the issue, refer to LON device can communicate in Vista, but fails in a Xenta Server / XBuilder
There are two options to correct this issue:
  1. Re-engineer the XBuilder project to use connection objects between the controller and the Menta program in the Xenta controller.
  2. The control task speed of the Menta program in the XBuilder project can be changed to a lower speed setting.
  • 18091
