Error: "Failed to install XXXX redist, error: 3010" during installation
  • Error: "Failed to install XXXX redist, error: 3010" during installation
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • HenrikTarpgaard
    HenrikTarpgaard
  • Benji
    Benji
‎2018-09-06 09:17 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 06:49 PM
During the installation of Workstation on a PC that didn't previously had any SmartStruxure software installed, you can get the message: "Failed to install XXXX redist, error: 3010"
Workstation
One of the build in Microsoft Visual C++ Redistributeable (VCRedist) installers (2008, 2010, 2012) is failing for some reason.
Restart the PC and start the installer again
Note: There is a similar issue but with error 1603, if you get this please see Getting the error "Failed to install XXXX redist, error: 1603" during installation.
  • 17247
