Error when installing SQL 2005 Express on a machine that had previously had MSDE installed
  • Error when installing SQL 2005 Express on a machine that had previously had MSDE installed
  • Derrick_Ratliff
    Derrick_Ratliff
  • CraigEl
    CraigEl
‎2018-09-10 06:18 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 09:01 PM
TAC INET
SQL 2005 Express
 MSXML 6.0 SP2 is causing the installation to fail
  1. Download the program linked below
  2. Remove SQL 2005 from the system
  3. Run the application to remove MSXML 6.0 from the system
  4. Re-install SQL2005 Express
MicrosoftFixit50568.msi.zip
For alternative solutions see SQL Express install fails on MSXML 6 and Failed to create or configure database on SQL Server! ([17] SQL Server does not exist or access deni....
  • TAC INET
  • 7226
