Different options on the CyberStation security key
  • Different options on the CyberStation security key
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
  • PaulFr
    PaulFr
  • Alan_Wood
    Alan_Wood
  • AbeMeran
    AbeMeran
‎2018-09-06 12:26 PM
What are the different options on the CyberStation security key?
Andover Continuum, Pelco
CyberStation
Documentation
NOTE: These are the options used to program a security key but not necessarily what shows when a key is read using MMC key reader.
For example when a key is programmed for FIPS-201 it does NOT show the -F when the key information is read using MMC key reader, one way to know if FIPS-201 is enabled is to look at the Allowed Credentials setting in the Cyberstation, the FIPS credential options will be blank if the Cyberstation key is not enabled for FIPS-201
CyberStation:
SU-INT           Single User Integrated
SU-HVAC      Single User HVAC
SU-SEC        Single User Security
LAN-INT        LAN Integrated
LAN-HVAC   LAN HVAC
LAN-SEC      LAN Security
CyberStation Options:
-U                    Unlimited Points
-P                    Programmer’s Version
-B                    Badging Option
-CFRB1           Basic CFR Compliance Pack – 1st Workstation
-CFRBV1        Basic CFR Compliance Pack – 2nd Workstation & up
-CFRA1           Advanced CFR Compliance Pack – 1st Workstation
-CFRAV1        Advanced CFR Compliance Pack – 2nd Workstation & up
-D                    Data Exchange Option – includes Personnel Import Utility
-E2, 3                Endura integration option
-F1, 2                FIPS 201 option
-USB4             USB Key
1    Option requires special approval before it can be enabled.
2    Option only available through software upgrade process; cannot be ordered with new P/N configurations.
3    New option introduced in v1.91; required per workstation for integration with a Pelco Endura system. Currently this is free as of 8/2/14 but needs a cookie       from repair for this option to work
4    USB Key Option is mandatory for new orders
Note: The Continuum version number of a key, allows it to operate with all Cyberstation versions up to that release.
Labels (2)
  • CCTV
  • 7776
