Connecting from a TAC Vista Remote Workstation gives error "Ensure that TAC Vista Server is started"
  • Connecting from a TAC Vista Remote Workstation gives error "Ensure that TAC Vista Server is started"
  • CraigEl
    CraigEl
  • Jonas_Brissman
    Jonas_Brissman
  • Benji
    Benji
‎2018-09-06 02:38 PM
Last Updated: Administrator CraigEl Administrator ‎2025-08-28 09:46 PM
When attempting to connect from a TAC Vista Remote Workstation, the following error appears:
This occurs even when DCOM settings appear to be configured correctly.
TAC Vista
  • Vista Server
  • Workstation
This issue typically arises when both the TAC Vista Server and the Remote Workstation are part of a workgroup rather than a domain. In such configurations, authentication and DCOM communication can fail if certain conditions are not met.
To resolve this issue:
  1. Verify DCOM permissions are correctly configured on both the server and the workstation.
  2. Ensure that the Administrator account password is identical on both machines.
    • This is necessary for authentication in a workgroup environment.
  3. Restart both the TAC Vista Server and the Remote Workstation after making changes.
Additional Notes
  • This issue does not typically occur in domain-joined environments, where centralized authentication handles these permissions.
  • For more information on DCOM configuration, refer to the TAC Vista DCOM setup guide
Tags (2)
  • 3432
  • JonasBrissman25
0% helpful (0/1)
