Configuring Vista Server to run on Startup
  • Configuring Vista Server to run on Startup
  • CraigEl
    CraigEl
‎2018-09-10 01:29 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 01:35 AM
If the PC is shut down or rebooted, Vista Server can be configured to run automatically on startup of the PC. This is not the same as running Vista Server as a service (for information on that, please see Registering/Unregistering TAC Vista Server as a Windows service). The server still runs as an application, but starts once at Windows Startup.
TAC Vista
  • Microsoft Windows
  • Vista Server
In the event of a power loss or reboot, the Vista Server will start automatically for the user, which enables trending and event logging, without requiring a manual start of the application.
These instructions are tailored to the Windows 7 environment, but the process is very similar in all Windows versions (add a shortcut to the application to the Windows Startup folder):
  1. Open Windows Explorer and navigate to C:\Program Files\Schneider Electric\TAC Vista 5.1.X
  2. In that folder, locate Tacos.exe
  3. Right-click on Tacos.exe and select Send to > Desktop (create shortcut)
    This will place a shortcut on the desktop to be used in a later step.
  4. Click on Start > All Programs
  5. Locate the folder called Startup
  6. Right-click on Startup and select Open all users
    This will open a Windows Explorer window to the appropriate folder
  7. Drag and drop the Tacos.exe shortcut from the Desktop to this folder
  • 6019
