Compatible versions of I/NET and StruxureWare Building Operation software
  • Compatible versions of I/NET and StruxureWare Building Operation software
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
  • Derrick_Ratliff
    Derrick_Ratliff
  • Roger_Bently
    Roger_Bently
‎2018-09-06 12:19 PM
Version of I/NET software and StruxureWare Building Operation software
EcoStruxure Building Operation, TAC INET
  • Windows 7
  • I/Net versions 2.40 and greater
With the release of StruxureWare Building Operation's integration with I/NET, customers want to be prepared for it when it comes out and needs to know which version of I/NET software they need to be running to do so.
For the initial rollout, 2.42 was listed as the preparation build to upgrade to for StruxureWare.  Users can upgrade to this build or the current build (2.43 at last edit) and begin upgrading all bin files. This will be required for StruxureWare integration. The bin files did not change between 2.42 and 2.43.
Each release of StruxureWare may have a corresponding release of I/NET.  For the time being users will be required to upgrade both I/Net and StruxureWare at the same time. The upgrade from 2.42 to 2.43 is a no-cost upgrade. It should be considered a best practice to upgrade I/NET and StruxureWare at the same time even when not required.
 The 1.3.0.938 release of StruxureWare requires I/NET 2.43. If the site upgraded to 2.42 they will not need to upgrade bin files for the controllers.
Labels (2)
  • TAC INET
  • 7984
