CLX Expansion Card for 7798B
  • CLX Expansion Card for 7798B
  • Roger_Bently
    Roger_Bently
  • CraigEl
    CraigEl
‎2018-09-10 12:24 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 06:48 PM
Expanding a system with a 7798B and unable to connect to other controllers.
TAC INET
  • All versions of I/NET
There is no expansion card to connect the LAN Controllers together.
The 7798B requires a CLX Expansion Card to be plugged into the slot to allow it to communicate to other controllers. The part number for this is LAN EXPANSION OPTION FOR RS-485, CLX. See Additional information on CLX LAN Expansion Option for RS-485 for more information on the CLX part.
  1. Take the device off the wall, unplug all wires including power.
  2. Insert the CLX card into the slot on board, be careful not bend any pins while doing this.
  3. Connect the wires again in their respective terminal with the LAN wire connecting to the CLX card, Sublan to those devices and power.
  4. Put the device back on the wall, set up accordingly and it should be communicating to the controllers now.
  • TAC INET
  • 5743
