Adding a Xenta Programmable Controller to an NL220 System
  • Adding a Xenta Programmable Controller to an NL220 System
  • Cody_Failinger
    Cody_Failinger
  • Derrick_Ratliff
    Derrick_Ratliff
  • Trey_Boothe
    Trey_Boothe
  • CraigEl
    CraigEl
‎2018-09-07 07:02 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:19 AM
TAC Vista
NL220
Commissioning a Xenta programmable controller in NL220 needs to follow a certain procedure in order to prevent various issues from occurring, such as controllers not showing online in Vista Workstation, etc.
Adding a Xenta Programmable Controller to an NL220 LNS system.
  • Preparation:
    • Create the Menta File
    • Install the Controller
  • Adding the Device to the LNS database
    • NL220:Create a Template for the device type. See NL220 Useful Functions and Shortcuts on how to create a template.
    • NL220:Add a node using the correct device Template
    • System plug-in: Assign Neuron ID and Menta file
    • Add and match I/Os if applicable
  • Bring the Device to the Vista Database
    • System plug-in:
    • Update TAC Network
    • Drag controller to an existing group if desired, and delete the now empty group
    • Create group bindings
    • Assign Neuron ID for the I/O modules
    • Update the TAC Network again
    • Check TAC Network
    • Update Vista Database
    • Check that your network is attached and OnNet
    •  Download Application and Parameters
  • Bring Vista Db online
    • NL220: Commission and download the device (ignore I/O modules.)
    • System plug-in: Commence Communication (if needed)
NOTE:  It is very important that you Download Application and Parameters in the Vista system plug in THEN Commission the device in NL220.
  • 4222
