SLEASXXXB
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • SLEASXXXB
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2025-05-12 01:42 AM . Last Modified: ‎2025-05-12 02:08 AM
1428
SLEASXXXB
Hi
I am searching for people who have seen a lot of characteristics of NTC sensors because I suspect there is a simple error in the characteristic definition in our datasheet.
In this discussion, I am referring to the document
F-28272-1 nk November 2022 titled
"EasyLogic™ Sensors  Temperature Sensors – Analog"
I'm wondering if the point 20°C (68°F) Resistance with a resistance value of 11272 shouldn't be 12272.
All other points are located quite close to 10k Type3 thermistor type but this one is little bit to far for me.
  • Temperature Humidity & Air quality Sensors
SantiagoFraile
Ensign SantiagoFraile Ensign
Ensign
Posted: ‎2025-05-29 07:53 AM
Hi Piotr, thanks for bringing this up. Indeed, yes, the resistance value at 20°C (68°F) is 12272. I have already requested marketing team to update respective install. sheet. You will see document rev 2 with updates soon. Rgds.
NikhiL4
Ensign NikhiL4 Ensign
Ensign
Posted: ‎2025-06-04 12:06 PM
Cześć! @PiotrJakubczyk , thanks for bringing this to notice. As informed by @SantiagoFraile, spec sheet is updated - https://ecoxpert.se.com/documents/10807/1507746/EasyLogic+Sensors+-+Temperature+Sensors+-+Analog+-+I...
Please note:
It takes a while for se.com to actually be updated with it, but it’ll be there too eventually.
Pzdr
Replies 4
MikaelKrantz
Guinan
Posted: ‎2025-05-12 03:40 AM
Please make a support case, so R&D could have a look into this.
CraigEl
Posted: ‎2025-05-12 03:52 PM . Last Modified: ‎2025-05-12 03:55 PM
@PiotrJakubczyk based on the tabl;es published by Veris and available in Temperature Sensor Resistance Charts, the value of 12272 looks correct:
As @MikaelKrantz noted, if you open a support case we can have the document reviewed and corrected by the Product Manager.
SantiagoFraile
Ensign
NikhiL4
Ensign
Please note:
Pzdr
